Arial connector on back of set seems to be a prob if you disturb tv even slightly the picture breaks up and there is noise of disturbance,when tv is working now that we have retuned with a new loft arial digital type everything is better than ever,it just happens from time to time all on its own,is this a common fault.
SOURCE: picture problems
The pixelation is probably caused by MPEG2 compression on the DVD and Virgin media video streams, the blur is probably caused becasue you are displaying a standard definition signal on a high definition TV.
However if a high-def source still has these problems then you may have a faulty TV, your best bet is too hook up a high-def source such as a HD/Blu-ray player or PS3/360 games console.
Should a high-def source look ok, then you may have some look changing the display settings on the TV to try and improve picture sharpness and color balance.
Thanks.
SOURCE: can't retune sharp aquos lcd tv
This is the best place that's near the manual you need.
They have the LC32D44E manuals, but not the "BK" at the end. I think the "BK" just means BLACK.
But, I think it will work for your TV.
Here's the link:
http://www.sharp.co.uk/page/downloaddrivermanuals#
Click on the "Sharp Europe - Manuals and Download "
Then, Operation Manuals
Then, LCD-TV
Then, put your TV model# for the search.
SOURCE: no digital yet tried to retune but greyed out.
Just got through to Samsung support. Turns out the freeview card had frozen and needed a reset. To do this put tv on standby. then press in serries these buttons on the remote: 'info' 'menu' 'mute' 'power' TV will then turn on with a default screen. Press 'arrow down' button untill you reach option 12 'reset' . then push the 'right arrow' and tv will reset and start in plug and play mode and commence a scan when you've set the time. Just retuned mine and its back to normal. Hoorah!!! :-)
SOURCE: No video signal on Toshiba TV
replace the power cable of your toshibal tv from 3 pins to 2 pin type.
this is becuase of the earth of the TV, thats why it is better not to eart the tv.
[email protected]
i seem to think that the prob may be the tv arial connector,it seems weird that we have a perfect picture for hours on end then all of a sudden you get probs with piksalation and noise ,,then as quick as it arrives ,it goes again,but sometimes by simply moving the arial connector you can cure it for many hours till it happens again.
