Need to figure out how to put numbers on speed dial on the new Rumor Reflex. Can't find it in the user manual.
Go to the contacts list. Hit more. Settings. Speed dial. tap a number and select the contct/phone number combo to call.
(Source: I literally just did this on a customers cell phone in best buy mobile)
SOURCE: how do i unlock my lg rumor from sprint to do anything?
it can be unlocked by calling your carrier and they will give you the infomation unlock code as long as the account is current and not delienquent if canceled it will cause some of the features not to work on the device
SOURCE: Krzr speed dial numbers
First, go to Menu. Then, number 4. Speed Dials. Then, if you wish to move your numbers around, simply click on a filled up speed dial slot you wish to change. It will take you to an Unassigned number, where you will click again. Then, there is an open spot where the name you just moved was. Find the name you want to be there, click, and scroll up to find the empty slot, then click.
SOURCE: LG Rumor - stoping Sprint music on startup & shutdown
you just turn the voluem to SILENCE ALL, that should do it.
SOURCE: password protect text messages on lg rumor for sprint?
go to menu then settings then security then choose lock and restrict this will allow you lock different items on the device you choose
SOURCE: I would like a users manual for my lg Rumor ii
Hello
You will be able to download the manual HERE.
Kind regards
Andrea
