I don't know what machine you have but some have clips you can push back with a putty knife or flat screwdriver just put the putty knife in the crack at the top of the front panel & slid it over till you hit something that will most likely be the clip push it in. Some have screws 2 at the bottom take them out & pull out on the bottom that will let the clip come out at the top. I would check for the screws first. Some have 2 front panels the bottom has clips you might be able to just pull out on the bottom panel at the top or use a screw driver to pry out. then check or screws at the bottom of the top panel. I hope this helps these are some machines there may be others. Good luck
SOURCE: wheezing sound
The inside tub moves on the spin stage only and cause the water, by a centrifugal force, to be forced out of the clothes. During the wash cycle,the tub is stationary and the agitator moves forth and back. If you would like to remove the agitator - Remove the inner agitator cap (inside the top of the agitator) and then open the screw (be aware not to lose parts !) Good luck !
SOURCE: Whirlpool duet washer has rock, marble, or something stuck inside
as long as your sure its an item between the tub assy the baffles in the drum can be removed and item fished out. but ifsomething snapped on the rear of the drum you would need to replace it. the baffle part number is 8182233, its about $40 thinknin thats worth a try before 475. the lower acess panel could also be removed and the main tub to pump hose could be removed which would give you a 3in hole to look through and try to grab somethin. worth a try
SOURCE: sock stuck in outer tub whirlpool cabrio
youll need to "pop" the main top.. then unsnap the outer ring that cvers the outer tub. if you look at the center of "agitator/ or bump plate depending on model" theres a small cap that will come of fand reveal a 7/16 screw remove the screw, and then oyull be able to lift the entire inner basket right out to retrieve any debris.
SOURCE: machine will not drain and spin
http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenith/4681EA2001D/New.aspx?ModelMfgName=LG+Electronics+Incorporated&ModelBrandName=LG+Electronics%2fZenith&ModelNumber=WM3431HW
you need a new one of these. i took mine COMPLETELY apart and found the impeller jammed. the impeller is a magnet in a sealed plastic carrier with an electro magnet around it. the electro magnet energizes , the two opposing fields spin the inner magnet ( just like a fish tank filter good idea actually!) the inner magnet on mine had a slight crack from factory causing vibration and allowing debris past the seal then jamming the impeller. to check yours drain it with the small drain tube, then get a towel or two and place around the unit at the floor.pull the large black drain cover off and after the gushing tidal wave look inside. you will see the white impeller. try turning it with w screw driver , pen or whatever. you may be able to remove and then clean / reassemble and be good as new. i only needed two tools to tear the machine apart. a Phillips screwdriver and pliers to get the clamps on the pump (2) and the clamp back on the door to drum gasket.
SOURCE: My Whirlpool Duet front loader is ripping my
My washer ruined 2 king sheets 3 shirts and brand new jogging suit, so I know what you mean! The rubber gasket ...it had 2 metal bands..one on the inside which is a wide one and a small thin one on the outside of the gasket. You really can't see the wide one unless it has started to slipped off or break. or by taking the ting one off,..my wide band came loose which caused the screw to be exposed just enough for something to catch on it, tearing the material, it kept wrapping around and around untili eventually the band came completely off. I hope this helps.
Linda
