HI DEARCONNECT UR PHONE TO PC WITH ORIGINAL DATA CABLE PRESS AND HOLD HOME+SLEEP BUTTON UNTILL IT SHOWS THE CONNECT TO ITUNES SCREEN COMES AND THEN RESTORE YOUR PHONE
SOURCE: My iPhone is disabled for 4,566,757 mintues, HELP!
The only way is to reflash a new firmware and wipe the code as well as the phone clean.
To do this start itunes on your computer. Then connect your phone to the computer. Once itunes detected your phone hold the POWER and the HOME buttons down at the same time for about 10 seconds. Once the phone flashes off, let go of the POWER button and keep holding the HOME button until you see a message on the itunes telling you that your phone is detected and needs to be RESTORED. Follow directions and it will do its job. I appreciate your positive vote. Thanks
SOURCE: sleep button wont work and its disabled
Could you clarify what is the sleep button?:
- The home button on the front
- The power button on the top
- or the vibration disble button on the left
Probably the flex cable that connects the button to the motherboard is not working. These parts are cheap and easy to install. You can find the replacement connectors for all these buttons here:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ObjectPath=/Shops/demo132390/Products/%22Piezas%20Iphone%203G%22
Testimonial: "nice one mate, thanks."
SOURCE: my iphone home button not working
May be the flex cable that connects the home button to the motherboard is damaged. This part is cheap and easy to install.
You can find a replacement here:
"iPod is disabled - Connect to iTunes" . This is because someone(or something?) has tried to crack your password too many times, which causes Iphone/Ipod to automatically disable itself to protect your data.
To restore your iPod, you must connect your iPod to iTunes with your iPod connector table. Make sure it is on and has this message when you connect it to your computer. Once connected, iTunes should detect it as usual.
Once connected, make sure you have all the proper sync settings enabled - for example, applications, music, photos, etc. Change something so that the Sync button in the bottom right appears in the iTunes window. Then sync the data.
When syncing is finished, turn on your iPod / iPhone and you should notice that the message is gone. Type in your password and the disabled message should be gone.
If the message is still there, try holding the sleep and home button at the same time until the iPod turns off, then continue holding the sleep and home button until a screen with the iTunes logo and a picture of the connector cable appears. This will put your iPod in Restore mode. With this option, you must click the Restore button in iTunes, which will delete all your data on the iPod.
i let my friend borrow the phone and he got the passcode wrong repeatedly, which i think is the problem. i need my phone back asap. any help would be much appreciated
The sleep button doesnt work??
Great unlimited free eShop codes without any human verification
free unused eshop codes
