Question about Nokia N86 Smartphone
My radio transmitter doesn't work... my mobile is nokia n86 8mp
  • 392 Answers
Firstly configure it to the nearest radio centres by downloading the radio stations and then play the radio according to your preference.if the radio signal is enough good then you can play it or else not.
Posted on Apr 07, 2012
3 Suggested Answers
6ya staff
SOURCE:
nan30
  • 9 Answers
SOURCE: When I text anyone it's
you may contact the service provider.....
Posted on Jun 04, 2011
jaisonthomas
JAISON THOMAS
  • 356 Answers
SOURCE: when i insert any sim
it seems to be a hardware problem.give it to a authorised techinician. but before that we will have a try.try reinstalling your phones firmware using nokia software updater.it may solve your problem.else do wht i sais initially.
goodluck
Posted on Sep 09, 2011
Radio wont transmitt
If there is no movement on the meter. have the SWR's check on the antenna system.. Free to have it checked. at a good shop.. You may have whats called a blown final..( final transmitter transistor) from high swr's. although you may hear, doesn't mean the antenna is OK. the other problems are a bad Audio transistor on the back corner, its the Large TO-264package/TO-218/TO-220 Styles. also. there a small diode on the solder side of circuit board near the 10.240 crystal, if its loose will also not let it key up or TX.
make sure all your coax cables are tight, and all the switches are in the correct positions... also doesn't hurt to have a second radio nearby to see if it will transmit to it. for testing. If you need more help let me know.
Dec 26, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
The wireless transmitter doesn't work
Mine quits working when the batteries in the outdoor part need changed .
Dec 15, 2017 | Centrios Audio Players & Recorders
When i insert any sim card in my nokia 5230 it doesn't power on & when i remove sim from it, it works fine in offline mode & also having charging problem when i connect charger to mobile it...
goodluck
Sep 09, 2011 | Nokia 5230 Cell Phone
I try to connect my blue-tooth headset model NOKIA BH-209 with my Nokia E63 mobile phone , but My NOKIA E63 mobile phone does not search NOKIA-BH-209, my NOKIA blue-tooh BH-209 is working with an other...
PLEASE MAKE SURE THAT YOUR PHONE BLUE TOOTH IS WORKING PROPERLY IF YES TRY CONNECTING YOUR PHONE WITH OTHER BLUE TOOTH HEADSETS. IF IT GETS CONNECTED YOUR PHONE DOESN'T SUPPORT YOUR HEADSET. IF IT DOESNT YOUR PHONE ISN;T WORKING GOOD.
Jul 18, 2011 | Cell Phones
Got a midland weather radio problem wr100 series. all county codes in and channel set. was working for awhile and now no alerts at all. keeps now saying check reception.
Turn your radio off and then on again. Then press the weather/snooze button. Do you hear the broadcast from your local transmitter? Check NOAA to make sure the station is broadcasting (not down for repairs). Try setting the radio to a different transmitter that covers your area.
You may need an external antenna for the radio (http://www.midlandradio.com/Weather-Radio-Accessories.BPE/18-259W ). Beware: when you use an external antenna, you may receive a broadcast from a different transmitter (farther away). In that case, the weather alerts for your county will likely not come in.
I hope this helps.
(we have two weather radios that are on full-time. The one set to a secondary transmitter does not receive the S.A.M.E. test signals or watches. (It can't be positioned to receive from the primary transmitter clearly.) It does receive warnings for the county correctly. The on/off routine has to be done every few weeks since it doesn't get the test signals. We tried an external antenna and kept getting transmitters from other states and missed tests, watches and warnings. Fortunately our main weather radio does get the primary transmitter and gets the tests, watches and warnings.)
Jun 27, 2011 | Midland WR-100 Weather/RDS Radio
I want to know how do I unlock my Nokia E5,
Do you wanna to unlock your NokiaE 65 mobile ? When you originally buy your mobile it will be locked to a specific network i.e. it won't work if you use a SIM card from a different network , you need to unlock it according t the network you reside , for that make use of the unlocking site , i got the unlock code here wickedunlock for unlocking my mobile under orange network & i unlocked my mobile safely . make use of unlock code & unlock it under orange network & gain solution at cheap cost . i hope this would be helpful for you ...
Jun 24, 2011 | Nokia E5 Cell Phone
My nokia 3230 doesn't read memory card.
There is the problem with Memory card connector or Memory card IC try to replace both it may get solved. if your Mobile technician then only try this if not then Please Visit your nearest Nokia Service Center(Nokia Care) they will do it properly.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up &
Testimonials //
Jun 22, 2011 | Nokia 3230 Cellular Phone
Cassete adapter for Ipod nano wont work in the truck do we need to have a certain radio station?
If you're using a cassette adapter it doesn't need to be set to a radio station your truck should be set to tape input. However you could get a 12V lighter FM transmitter that will play the iPod over the radio and with that you'd need the radio set to a specific station.
May 10, 2011 | Dynex Docking Station with Remote for...
Open Questions:
See all Nokia N86 Smartphone Questions
Nokia N86 Smartphone Logo
81 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
Zaid Anarwala
Zaid Anarwala
