I have a whirlpool gold side by side refridgerator. I lost the manual and I have to change the water filter. the model number is gs5shaxtl01.
please help thank you
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Filter is at the bottom of the fridge, in the grill, 6-8" from the left side.
Manual and parts list is available at http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=gs5shaxtl01&siteCd=WHRCOM
Regards,
MrBoo
1. Press the eject
button to release the filter from the base grille.
2. Pull the filter
straight out.
3. Turn the cap
counterclockwise to remove it from the filter.
IMPORTANT: Do
not discard the cap. It is part of your
refrigerator. Keep the cap to use with the replacement
filter.
4. Align the ridge
on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
NOTE: You can run the
dispenser without a filter. Your water
will not be filtered. Simply insert the cap all of the way
into the
base grille and rotate the cap until it is firmly in
place.
5. Remove the
protective covers from the O-rings. Be sure the
O-rings are still in place after the covers are removed.
6. Push the filter
into the base grille. The eject button will pop
back out when the filter is fully engaged.
7. Flush the water
system. See “Water and Ice Dispensers.”
gaskets. Do not use paper towels, scouring pads, or other
harsh
cleaning tools.
