I'm able to send faxes. However, I am not able to receive faxes. My ext phone line attached to the rear of the fax machine does ring, I hear a fax transmissin noise and my fax machine instantly appears to know it is receiving a fax. I am not able to receive the fax. I get a COMM ERROR trouble display. Please assist me. Thank you.
SOURCE: black vertical line appears on faxes i send and receive
Small slit of glass "scanner glass" needs to be spotlessly cleaned, open lid to left 2cm wide runs width of lid.
G'day from Oz
SOURCE: Problem Faxing sending and receiving faxes
disregard post....i have it, have been working onb it all evening and the fax does not work.
SOURCE: fax interrupts phone call
1. Make sure your [RINGS TO ANSWER] settings are more than the same settings for your answering machine.
2. If someone tries to make a copy while the phone line is in use, they need to press number 1, as if telling the unit that they want one copy. If not, the unit will think you are trying to receive a fax and will interrupt the communication.
Be blessed.
SOURCE: CLX-3160FN SAMSUNG Printer/Scanner/Fax
Replace your USB cable with a good quality, thick USB cable that does not exceed 10ft. Let me know if the problem persists.
Be blessed.
SOURCE: FAX Conformation printout
Press the "FAX" bottom, press menu, press arrow until you hit "FAX set-up", press OK, press arrow until you hit "sending", press OK, press arrow unti you hit "Send Report", press OK and press arrow to "ON" and press OK and it will saved.
Everytime you faxed something it generate a report.
Hope it will help you.
