Question about Pelican Xbox Eclipse II Wireless Controller (XBECIIWICO)
I need to know which buttons R and L are?
My son is having trouble figuring out which button R and L are on his pelican xbox controller! Hes only eight so I found him some cheats and in order to put them in he needs to know which buttons R and L are? So if anyone could help me that would be awesome
  • 34 Answers
Hello! The xbox controller has 2 triggers on the underside of the controller. when you are looking at the top of the controller the trigger on the left is button l and the one on the right is the trigger r. I hope this helps
Posted on Nov 11, 2008
SOURCE:
My son has a xbox360 and were trying to get xbox live to connect and it wont we had it working just fine on his brothers hes not home so we hooked it up to the other xbox 360 and it wont connect
1 Disconnect all accessories and wired controllers from the Xbox 360.
2 Hold the "Guide" button down for three seconds on any wireless controllers, then respond to the prompt on your television screen to disconnect the controllers from your system.3 turn on the wireless headset by pressing the "Power" button in the center of the earpiece. 4 Press the "Connect" button on the front of your Xbox 360 system. 5 Press the "Connect" button on the wireless headset. The ring of lights around the power button of the Xbox 360 system should spin and blink once. One of the lights should remain lit up, indicating the port number that the headset is using. If you do not see any lights on the system, you may have a faulty wireless headset.6 Press the "Guide" button on your wireless controller to reconnect the controller to the Xbox 360 system. If you are using a wired controller, you can plug it back into the system.7 Press the "Connect" button on the top of your wireless controller to sync the controller with your system. You should see the connection light around the "Guide" button on the controller light up, indicating which port you are connected to. You should also see a corresponding port light in the ring around the power button of your Xbox 360 system 8 Press the "Connect" button on the wireless headset until the port light on the headset matches the light on the controller and Xbox 360 system. For example, if you are the first player, the light for port number one should be lit up on the Xbox system, the controller and the headset. When all lights correspond, your headset should be properly connected.
Sep 29, 2011 | Microsoft Xbox 360 Console
Hi, son was given datel xbox wirless controller, to sync it says press home, then press and hold sync, all on controller, i have done this, then it says 'to complete process, press the sync button on the...
Yeah to sync the controller all you do is find the little button on the back on the controller on the left handle thing and hold it and the sync on the xbox. I had trouble at first two. But its a great controller.
Dec 29, 2010 | Datel Xbox 360 Turbo Fire 2 Wireless...
The guide button on my pelican wired controller for xbox 360 flashes green but wont work
You are having a controller board problem I would suggest getting it repaired or replaced or you can take it apart and make sure everything is in working order such as no burnt buttons or melted solder.
May 09, 2010 | Pelican Wired Controller for PlayStation 3
How do i link the pelican remote to the xbox 360?
There should be several USB ports on your 360. There should be one in the back and two in the front lower part of the console. It is hidden beneath a small flap you can push in with your fingers and slide the cable into the usb
Apr 10, 2010 | Pelikan PELICAN PL-3601 Xbox 360(TM) TSZ...
I have a old xbox system and my wireless controllers by pelican brand pl-2050 one will not link up to the xbox what to do!!
Check to verify that your batteries are installed correctly.
- Check to verify that the power is on. Check to verify that the signal LED is blinking
If this does not solve the problem, do the following:
1. Make sure your Xbox is turned off.
2. Remove the battery lid and place 2 AA batteries into the Blade 2.4 Street Wireless Controller. Make sure the batteries are inserted as shown in the battery compartment.
3. Insert the receiver into your Xbox controller slot of your choice and power up the controller FIRST, then your Xbox.
4. Press the Connect button on the receiver once. Your signal LED light will begin to flash slowly.
5. Press the Back button on your controller. This will program the receiver to connect to the controller each time it is uses.
6. Turn on your Xbox and insert a game.
Aug 06, 2009 | Pelican PL-2050 XBOX EDGE 2.4 GHZ WIRELESS...
The program button will not reasign any of the buttons
are you using the game to reasign or the actual windows program
Jul 07, 2009 | Pelican XBOX Tomahawk Flight Stick...
Wireless not working
Run the network tests from within the 360 menus - looking especially at the result for network address translation (NAT). If this is either limited or fail, you will need to change your router for one which is compatible with xbox live. Try xbox.com to work out which routers are recommended.
As far as your router kicking him when you connected your pc, then you must have altered the access permissions of the router maybe by accident.
If all else fails, turn off the pc, router, modem and 360. Find the reset button on your router and press/hold this for at least five seconds. Turn on the modem, then the router. Let that settle for a minute, then connect and setup 360 and laptop.
Apr 10, 2009 | Pelican PL-2050 XBOX EDGE 2.4 GHZ WIRELESS...
Wireless controller
you have to link controller to xbox under disk tray to right theys a small round button press this green rings flash, whilstflashing press xbox button on controller so it also flashes this will link them
Jan 03, 2009 | Microsoft Wireless Controller for Xbox 360...
Need to know which buttons are R and L
Need more information for this... if you would like help.. but it really wouldn't matter if you have your remote taken apart and you just need to put them back in but R stands for Right and L stands for Left if you didn't know that
Nov 10, 2008 | Pelican Xbox Eclipse II Wireless...
Pelican Cooling stand for Xbox 360?
hi dirtrider,
The ive used many fans such as the interloper, and they all were faulty, didnt work very well, and some were extremly loud.
The pelican, although, is what I us now, and I have yet to find anything wrong with it, the looks are kinda weird but its worth it, also rememberto turn the fan on/off at the right times, because its powered by usb, and theres power feeding through it constantly while its turned on.
Good luck, and happ gaming.
Dec 29, 2007 | Microsoft Xbox 360 Console
Pelican Xbox Eclipse II Wireless Controller (XBECIIWICO) Logo
902 people viewed this question
Top Pelican Video Game Consoles & Games Experts
Nikki  Mclean
Nikki Mclean
Marvin
Marvin
Are you a Pelican Video Game Console and Game Expert? Answer questions, earn points and help others
