check bar oil holes,
check oil tank pickup filter - should be clear, clean oil tank
remove drum and clutch, check drum and check oil pump driver arms ( could have worn or broken off and drum is not driving it around ,
check the worm part of the pump driver as well ,
remove pump oil pickup lines and outlet lines , check that both lines are clear and that the pump is not all bound up / stiff or damaged if everything else is good
i would replace the pump and reassemble , tighten clutch anti-clockwise ( clockwise to loosen it ) make sure drum cut out engages oil pump driver arms
as a rule if replace pump also replace pump driver , they are matched
here is web site for parts
http://www.partstree.com/parts/?lc=husqvarna&mh=10
slect your year from list and open up
cheers hope it helps
paul
use bent bit of wire to hook it out,it will come clear of the hole
