The screws that hold the top plastic cover down are badly rusted and can't get anything to turn them to unscrew them. The screws are down in a well like area where usually a socket with an extender can get to them. I heard of a drill bit like tool might do the trick but don't know what you call the drill bit that reverses a problem screw that.
SOURCE: toro super recycler mower will not stay
Try replacing the fuel and spark plug. Gas may be bad. Get some fresh from the station not from the can sitting in the garage.
Drain the fuel system and put the fresh gas in.
HTH
Good Day.
SOURCE: Looking for a service manual to repair Toro Super Recycler GTS5
Try jacks small engines online!
SOURCE: starter rope broke how do i replace it
You have to remove the whole engine air shroud over the flywheel to gain access to the recoil and rope mechanism. If you need specific help on your exact model engine I need all of engine model type numbers 5 to 6 char then 4 char then 2 char i.e XXXXXX-YYYY-ZZ for B & S Honda numbers are by the engine oil port on the base of the crank case. Thanks for using FixYa, Kelly
SOURCE: my toro recycler lawn mower is seeping oil on the
It is best to take the machine to a good repair shop like www.arcolawn.com and have a "leakdown test performed." This will prevent you from spending money and time in replacing gaskets that are going to go bad again because the piston rings are bad. If the machine passes a leakdown test then it is worth pulling the engine and installing a new sump gasket. under 20 bolts and you can do it yourself.
www.arcolawn.com has the parts diagrams if you type in your model
Joe
