Need rmote codes
SOURCE: rca remote, codes don't work for sylvania tv
Trata con esto.
Presiona el boton Code search y mantanlo asi hasta que el led se quede encendido suelta y presiona el boton TV despues vas a presionar y soltar el boton Power hasta que el televisor se apague despues presionas el boton enter y el codigo queda almacenado.
El Tv tiene que encenderse primero manualmente.
SOURCE: codes for sylvania tv
Try 0062 0004 0009 0135 0189 0183 0227 0456 0008 0068 0075 0141 0161.
Nigel.
SOURCE: I have a RCA Digital
If you are able to access the internet, I would suggest try getting your question answered by searching online. Several sources have answers to your question. They may not be the solution, but worth a try. Who knows, one of them just might work. Most of the time, it just takes a little patience and plenty of persistence. Be willing to spend some time searching. You might start by typing into the search box exactly what you're looking for. Good Luck!
SOURCE: what is rca remote code for sylvania model
Hello
Four digit codes for Sylvania TV with RCA RCR 311W remote control are:
1003, 1004, 1014, 1046, 1051, 1060, 1061, 1062, 1066, 1067, 1072, 1073, 1074, 1075, 1076, 1077, 1078, 1082, 1150, 1151, 1165, 1192, 1199, 1206
Five digit codes for Sylvania TV with RCA RCR4373N remote control are:
11864, 10054, 10030, 10171, 10096, 11271, 11314, 11394, 11963
OK.
11864,
006,007,010,011,013,016,027,
033,035,043,049,066,087,089
Programming method
[1] Press the button of the device you want to
control (for example TV).
[2] If the device turns on, press another button,
to confirm (for example CHANNEL UP)
[3] If the device you selected (TV) responds,
you will not need to program the remote.
If the device you selected (TV) does
not respond, you will need to program
the remote
There are very rare RCA remotes, with Sylvania TV can be programmed. Just try the above codes with your present RCA remote control. If it does not help, buy the above model RCA universal remote. You will get code list and all other related documents, how to programme it or so, with the device you do purchase. OK.
