Original problem was "Reset Power" error. Did all steps recommended by HP online help. After reset, "Align Page" still shows. If you hit OK, it goes back to "Reset Power". After reset, back to "Align Page" but it will not allow you to cancel or access Menu and all other buttons are locked up because it is stuck in "Align Page" mode. Please help : 0.. Thank you.
SOURCE: Error code 0xd05d010d reset power
Unplug the power cord from the All-In-One as well as the power outlet.
Plug the power cord directly to a wall outlet without surg protector. (if possible connect it to a different power outlet)
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
Then check and see
Good Luck
SOURCE: HP PSC 1610 Language reset
Press SETUP until you see 4. PREFERENCES. (Spanish-Preferencias) Press OK.
Press RIGHT ARROW until you see SET LANGUAGE & COUNTRY/REGION. (Spanish-Idioma & Pais) Press OK.
Press LEFT ARROW or RIGHT ARROW until you see ENGLISH. (Spanish-Inglés) Press OK.
When Prompted, press OK.
Press RIGHT ARROW to select the country. Press OK.
When prompted press RIGHT ARROW to select Yes or No. Press OK.
Here is a link to the User Guide. It's on page 93.
PSC1610 User Guide
SOURCE: My Officejet 6310xi All-in-one keeps going to power reset
Hi. I just got off of the phone with an HP case manager. I was ready for a refund, but he helped me and now my printer is working fine. The key is to have your Officejet 6310 plugged directly into a wall socket. The variations of power through a surge protector often cause a power shortage to the unit. The 6310 needs the 110 volts to operate. Surge protectors will sometimes rob the unit of this power. Follow these steps:
1. Unplug the power cable & ethernet/usb cable from the unit (stand alone mode). Let it sit for a minute.
2. Plug the power cable directly into a wall socket. Then plug the power cable into the 6310.
3. After it powers up, push the "Setup" button.
4. Right arrow to "2.Print Report."
5. Press "OK" button.
6. Right arrow to "4.Self-Test Report."
7. Press "OK" button.
A page should print showing alignment and color settings. Now you're back in business!
SOURCE: HP photosmart3210 printer problem error message
Hi
I found this I know your error not in here but it may work for
It worth a try nothing to lose and it may work.
I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it
Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: hp 7410 all-in-one won't power on - the screen
Have a look at this site. It worked for me and apparantly for lots of other people.
The person who posted the site is my hero
http://callitout.com/quotes/index.php/kick-it-to-the-curb/68/printer-wont-boot-up-start-cycle/
Testimonial: "you ROCK shirleyhome!! THANK YOU!! And, yes, the person who posted this site is a saint! :)"
note: HP recommends plugging the printer directly into a wall outlet.
