Display is blank n juno d no sound
Check the power adapter at the coaxial plug end that plugs into keyboard- is there power there? If so, is the socket on the keyboard loose at all? If so- the socket may be broken, If there is no power there, you either need a new power supply or you need to open it up to see if it is just the fues in that supply that failed.
If the plug inserts snugly as it did when new and it dopes not power up, the issue may be the power switch on the back- it may have dirty or corroded contacts- cycling the switch on and off several times rapidly should clean it.
If it still does not power up, there should be a fuse internal to the keyboard that would require you open it up to check it. If it is not under warranty, this is not an issue- if it is under warranty, it is something that should be checked in the shop.
SOURCE: My sustain pedal does not work on my Roland Juno-D keyboard.
Have you tried the pedal straight into the amp without going thru the Roland?
Does the sustain pedal turn on with the foot pedal or is it a separte stomp switch to turn it on?
SOURCE: roland juno-d, keys are either too loud or too
Normally you have to clean the conductive rubber "pills" AND the circuit board traces they get pressed down on.
USE ONLY 99% isoprophyl alcohol on Q-Tips to do the cleaning and be gentle.
Use of other product like deoxit and other contact cleaners will wreck the contact material.
SOURCE: we have the roland juno d and we can't figure out
you could try using 2 midi channels for two sounds.
SOURCE: Where can I take my roland juno keyboard to be repaired lost soun
juno, lovely instrument, try the synthesizer repair centre in london
SOURCE: I NEED TO KNOW HOW TO SET UP MY ROLAND JUNO D WITH
Simple way is MIDI out from Juno to MIDI in on MPC, then (depending on how you want to work), connect MIDI out from MPC to the in on the Juno. If you do this you MUST turn local control off on the Juno or else you'll get double triggers (internal + msg in from MPC). Now to record sequences on MPC , set MIDI to as track in setup window (on the 2500, this is accessed by pressing MODE then pad 9, then press button under the corresponding tab [on LCD]) then set your MIDI channel by port, meaning if your MIDI cable is physically connected to out A, in your LCD in bottom right corner it will show as follows: 1A. This indicates you are transmitting on MIDI channel 1; port A. Remember, MIDI IS NOT AUDIO!!!!! Since the Juno is a synth and not a workstation, all transport controls are handled by the MPC, that's pretty much it... Hope this helps a little, enjoy!
P.S. Go to mpc-forum.com its THE sh**! They also have links for their e-book I have one for the 2500 and its awesome!!!
