I have a Singer model 7422 and when I try to wind the bobbin thread it rotates twice, stops all the stitch lights blink and it beeps. I then have to shut off the machine and restart it. The bobbin pin is pushed over to the right. Also, the needle doesn't disengage, it keeps moving as well, any suggestions?
Your problem lies with the main shaft that is to tight to release the bobbin winder mechanism, because of old grease and oil becoming sticky. A short term solution will be to remove the needle, in order not to hurt you, and then hold on to the needle bar with your left hand, while engaging the bobbin lever with your left hand. This will prevent the main shaft to rotate and your winder should work. In the long term, take it to your dealer to clean the oil and grease. You will not be able to open the machine casing yourselve, as you might damage the casing and or electronics.
No se como se inserta el carrete en la bobina y no funciona. Como lo hago
