Our Peg Perego Train will make the noise, but the wheels won't turn and it won't move.
SOURCE: do I need to replace all tires on peg perego john deere
Hi!
On these, only the 2 rear wheels are the gear wheels. You will just need to replace the tires on those with the rubber ones if you choose to go that way.
SOURCE: peg perego gator grinding noise?
The Peg Perego Gearbox is the item that would make a clicking noise or grinding noise.
There are two different types.
One is a cross shape and another is a pentagon shape.
If you contact the folks at http://www.shopjandl.com/ they will be able to tell you what type you need. I get all my parts from them because they help me figure the problems out.
Hope this helps
SOURCE: wiring specs for peg perego polaris 700
I would contact the repair help at
They seem to know a lot about these toys
SOURCE: My son poured water in his peg perego santa fe ride on train
It might have shorted out the motor under the seat.
SOURCE: Peg Perego Gaucho Rock'in Worked for a minute than Stopped.
it sounds like a fuse is cutting it off.
They always help me with my repair problems.
hope this helps
