2004 Hyundai Tiburon 4 cyl.
1. Remove the Alternator Belt.
2. Remove the Water Pump Pulley
3. Remove the Air Conditioner Belt and Power Steering Belt.
4. Remove the Crankshaft Pulley.
5. Remove the timing belt cover
6. Remove the timing belt tensioner pulley.
7. Remove the Timing Belt.
8. (If Replacing) Remove Idler Pulley.
Installation is reverse of removal. Keep a close eye on the timing marks on the cam sprockets to make sure you don't knock anything out of whack.
I would strongly recommend replacing the water pump while you are replacing the timing belt. (The water pump usually comes in the timing belt kit.) Otherwise you are going to have to do this all over again when your water pump goes out. Good Luck.
Which engine? 4 cylinder or V6: Here's procedure for 4 cylinder:
DISASSEMBLY
1.
Remove the alternator belt.
2.
Remove the coolant pump pulley.
3.
Remove the power steering belt and airconditioner belt.
4.
Remove the crankshaft pulley.
5.
Remove the timing belt cover.
6.
If the timing belt is reused, make an arroI need instructions on replacing the timing belt - kckd109b.gif the turning direction (or the front of the engine) to make sure that the belt is reinstalled in the same direction as before.
7.
Remove the timing belt.
