SOURCE: pairing
1) Make sure headset is off. 2) Press and hold the answer button until the light flashes green and red. 3) If it only flashes green, press and hold both volume buttons until the light lashes red and green. 4) It is now ready to pair: follow the instructions in the bluetooth menu of your phone. When asked for the passcode enter 0000. 5) All done.
SOURCE: i need to know the pin code
Hi..
Playing with security codes may damage your device's internal components. It's better that you take your device to the nearest sevice center. The service personnel will surely help you out on this.
Thanks - billa
SOURCE: n97 connectivity problem with bluetooth HBH DS 200
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF,
then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
SOURCE: Master reset HBH-PV702
How to restart my hendsfree? pls answer me, i can connect it with no one
SOURCE: I try to connect my Sony Ericsson HBH-DS205
Hullo Tillgustaf
I understand you need an A2PD compliant bluetooth adaptor. I’ve just installed one on my PC at work, asked Windows to look for updated drivers on the internet and it has installed correctly.
You can get an A2PD adaptor from Amazon for £1.50 here
Best wishes,
Phil
