Garden Logo
A
Anonymous Posted on Apr 05, 2012
North star presure washer model# 3dx25gsi - Northstar Garden
1 Related Answer
Anonymous
  • 43501 Answers
  • Posted on Mar 03, 2010
SOURCE: I have a M157305J North Star pressure washer. The
The thermostat in the control is sticking... by turning it a bit you get it to release and kick back on...
You need to replace the control...
Heatman101
I have a north star pressure washer model 2SFX20ES3 and the pump is not working. The engine is working good. I pull the trigger and no pressure.
Hi
Sometimes you may have to allow a little time for the pump to prime itself and remove the air trapped inside. With the pressure washer at idle and the pressure hose fully extended, squeeze the trigger and see if you get pressure in a couple of minutes.
If you get no joy from that, your pump has likely checked out on you.
Hope this helps.
-Steve
Jun 05, 2015 • Garden
What is wrong when GE GFWW1100L2WW not filling with water
The water presure switch is open or the door switch is defective
1helpful
2answers
How does a compass always point to due north?
"Due North," by definition, is the direction towards the earth's north pole; or, visually at night, towards Polaris, the north star. Therefore, compasses generally do NOT point towards due North but, rather, point towards "magnetic north," as the other responder described, which is a variably located at some distance from True North, depending upon where the north-locating compass is situated on our planet. In most circumstances magnetic North is close enough so that people are willing to accept it as North in general terms. However, depending on your location, and upon seasonal changes caused by Earth's wobbling rotation (called precession) true North can be many degrees off from magnetic (from your compass's) North. In those cases true North must be determined using declination charts, which will tell you how many degrees to add or subtract on you compass in order to determine true North by the Magnetic North your compass is pointing to. For example, if magnetic North is 10 degrees west of true North at your compass's location (that is, your compass is actually pointing 10 degrees to the "left" of North), then you would correct by considering the +10-degree bearing point on your compass dial as True North--and, likewise, add 10 degrees to any bearing line you happen to determine using your compass. You have one other way of finding True North, which is celestially, by sighting towards the Pole star, aka Polaris, aka the North Star...that is, providing that the sky is UNcloudy and unsunny enough for the star to be visible. Of course, that only works for those located in the morthern hemisphere. Those south of the equator have a "south pole" star but it is not as accurate as Polaris in the northern hemisphere.
1helpful
1helpful
Heatman101
Mar 03, 2010 • Garden
4helpful
I want to remove the 4gpm pump on my pressure washer.
HI, It sounds like it is just stuck on the keyway as these can be very tight. You need to force the pump of evenly on either side and should come of if patient.
2helpful
What type of oil does the pump use? how much?
8.5 oz. to the red dot on the site glass.
SAE 30 / 30 wt Non Detergent Oil from your local auto parts house.
No pressure on hose
i have a karcher pressure washer i had to change the fuse box and pressure coils hope this helps .tom
Top Northstar Garden Experts
Mike Cairns
Mike Cairns
CJ Rock
CJ Rock
Are you a Northstar Garden Expert? Answer questions, earn points and help others
