I turn on tv blue led is on but nothing on screen, then power shut down after 30 sec. any advised what is problem. tv power supply part number 846-240-H3CZZSH same as tv polaroid power supply. thanks in advance
SOURCE: Polaroid LCD tv - model TLX-04244 Shuts itself off...
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
If your TV is less then a year old, still under manufacturers warranty.
I service these power supplies, for more info write to [email protected]
SOURCE: My Sceptre LCD TV (X32GV-Komodo0 power turns on
1. check power supply
2. check flyback
Ether or you have a ppower fauilure in the unit. and its probably blowing fuses.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: My Sceptre LCD TV Power turns on briefly (blue
Power supply is the place to look, look for bulging on top of the capacitors in the secondary side of the main power supply.
SOURCE: I cannot turn the T.V on no even with the remote.
n likely you are dealing with a bad powersupply
SOURCE: Wharfedale LCD3210AF
dose any 1 now how to fix this problem, i turn on my tv the light is just BLUE, the red light aint showing
