Removed rear casing from Tefal Ultraglide Easycord 50 to expose terminal block for but not sure how to remove terminal block from body for cord removal and replacement.
Terminal block is fastened/secured with body by a screw but before removing the terminal block from body, make sure that the iron element terminals are also disconnected. this can be done by opening the screws on other side of the cord terminals-3 in number as also in the cord. Otherwise the terminal block would not come out fully.In any case you normally do not need to remove the terminal block.
May not of explained, the model is an Ultraglide Easicord 50. can't seem to locate any screws eithe holding the terminal block in or fixing wires into terminal block, cord seem to be ferrule ended at each termination and pushed in to the block.
