The trunk won't open and the fuel door won't open
SOURCE: fuel door will not open
iF IN COOL CLIMATE DOOR MY BE FROZEN, THE POURING WARM WATER AND THEN OPEN. ALSO, THEN IS A MANUAL OPENING CABLE/DEVICE IN TRUNK LEFT SIDE AT BOTTOM JUST ABOVE REAR WHEEL
SOURCE: when battery is connected fuel door and trunk open
well for starters there is many factors at play here. 1. battery chargers need to be on and battery disconnected. make sure if it has a timer it did not run out and (the charger may also have an internal fues/ relay ) if it gets too hot it shut off. Was the charger on a high enough setting to compenstate for the drain and is your battery good enough to be charged even. constantly drained batteries will actully not hold a charge after awhile. most parts or even walmart can check batteries free>
The trunk lights and fuel door on the same fuse? otherwise I would say the trunk has a bad switch that is not making contact or is making poor contact and acting as the trunk is open. it may just be pinched wires that rubbed together make contact with your cars steel body. They may be seen in the trunk follow the wires from the release switch and see if it connects anyplace near the fuel door. I am sure it will.
SOURCE: The fuel door button does not work, but the trunk button does.
there is a cabel in the trunk that you can pull to open door same side as fuel door usly has yellow handel on it say fuel door
SOURCE: cant get my fuel tank
So the key wont open the trunk? there should be a pull cable in the trunk near where the gas door is to open the door.
