If your brake fluid is in need of changing, do so before long-term storage. Similarly, hydraulic clutch fluid should be changed before you store your bike; both systems may suffer failure if moisture gets in. Also make sure your coolant is fresh, as deposits can form from old fluid. For service intervals, consult your owner's manual.
SOURCE: winter storage
what to do with fluids?If your brake fluid is in need of changing do so before long-term storage. Similarly hydraulic clutch fluid should be changed before you store your bike; both systems may suffer failure if moisture gets in. Also make sure your coolant is fresh, as deposits can form from old fluid. For service intervals, consult your owner's manual.,,,
