SOURCE: Self cleaning MAytag Gemini GAS oven
A wonderful feature is that the ovens self-clean with the press of a few buttons. Only one oven can be programmed to self-clean at a time. Remove the oven racks. Turn off the oven light and close the door. Press the "Clean" button and then press "Auto Set" to automatically clean the oven for 3 hours. Press the "Auto Set" pad again to set the oven for a 4-hour clean cycle, or press the button one more time for a 2-hour cleaning. The oven locks when in cleaning mode. When the oven is finished cleaning, the word "Cleaned" will be displayed on the control panel, and the oven will remain locked until the oven has cooled, which takes about an hour. To cancel the self-clean cycle, just press the "Cancel" button. Simple!
SOURCE: I have a whirlpool self
Hi Headcl
F1 E2 fault code is an error on the control board of the stove. By disconnecting the power from the unit for about 0.5 to 1 minute and then reconnecting the fault may go away after a minute or two (reset). Otherwise the clock (ERC) has to be replaced.
Regards
SOURCE: How do I use the self-cleaning oven feature
An easier option for you would be to download a replacement manual. Go to managemyhome.com and register. This is a FREE service. Once registered, log in and go the "Home Manager" link at the top of the page. Look for the "Owner's Manual" link under the drop down menu and click on it. Enter your Brand Name and Model Number. Your Owner's Manual is listed in a downloadable .pdf format that you can save to your computer or print out for ready reference. I hope you find this information helpful. If you have further questions, please let me know.
SOURCE: I do not have the manual to my self clean oven. I
You didn't provide a model number, so I couldn't give you an exact location for your manual, but you should be able to download it at:
http://www.maytag.com/support/manuals_literature.jsp
SOURCE: how does self clean oven work
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
you oven to go into the self clean mode(self destruct)....check out
this tip...
Self
Cleaning Oven Problem
heatman101
this tip...
Self
heatman101
