SOURCE: adrian i have sony-vaio vgn-130g its dead no sighn
my mother board is damage. whats the cost of it.
model: acer aspire 3680-2022
email: [email protected]
SOURCE: sony vaio VGN FJ290P password reset sony vaio VGN FJ290P
I have set the password for administrator when i entered the bios set up. you can change its setting but not the configuration unless you've entered the password. you can't change the password with a new one if you cant enter the old password. Next time dont forget your password because laptops has its security even when stolen you cant open its bios set up if its protected by password. CMOS battery is in the mother board. You need a service technician to open your laptop to reset the bios setup battery.
SOURCE: i want sound driver for sony vaio VGN-N325E
click this link for download and install this driver also
Thanks
Good Luck
Appreciate to rate as "Fixya"
SOURCE: Motherboard for a Vaio VGN CR sries
MBX-177A DAGD1BMB8B0 (<-Zero)
Part number A1337186A from Hyratech.
Testimonial: "Thanks so much for that!!!"
SOURCE: Is the cmos battery on a vaio vgn-fe31m on the
Yes the cmos battery is on the motherboard.
Every motherboard that runs a computer has a backup battery to run the circuit while turned off. This battery runs the real-time clock (RTC) and is referred to as the CMOS battery. By keeping the clock active and running even when the computer is switched off, power up/down cycles can be logged and before the internet, your computer could keep dates accurately. It also serves to maintain the system configuration settings in BIOS memory based on RAM or FLASH RAM.
I'm trying to fix one of these laptops, but I need to know if the motherboards will interchange, I only have the nw220f at the moment, and can't find any details on the nw320f.
I know the cpu's are different ,but are the boards the same?
