Do I need to change the bios before ssd install? Or ssd then BIOS then os?
SOURCE: SONY VAIO PCF-FRV25 BIOS UPDATE
Start by downloading the latest BIOS update file from SONY here: http://esupport.sony.com/US/perl/swu-list.pl?mdl=PCGFRV25&LOC=3
Then read the instruction they give and follow them.
Good Luck
SOURCE: i need to flush my bios.forgot password. Sony vaio pcg-7g1m
Try This:
Reseat the CMOS battary:
How to Change/Reset a BIOS password
Posted on 30 December 2008
Tags: Tech News, Tutorials
If you are a normal computer user who has forgot his BIOS password and you are unable to access to your BIOS, then you need a simple way to change your BIOS. Its not that hard because you just need a simple trick to reset your BIOS password.
Open your CPU cabinet after switching OFF the power and then try to locate the CPU battery which can be found very easily. Once you locate your battery you need to remove it once and restart your PC without the battery.
Note : Once you remove your battery from the mother board, you will find that all your time settings in your computer would be lost, and some softwares may stop working which are based on your computer time.
You need to shut down your PC again and now add back the battery which will enable you the time saving feature and also reset your BIOS password.
SOURCE: who to bypass sony vaio bios password
It is not easy to unlock Sony Vaio Laptops Bios Passwords.
I was searching and i found this
http://www.spunlock.com
They have remote unlock for sony vaio laptops and have been recomended.
Regards,
SOURCE: my left mouse button on sony vaio vng-nw150j isn't working
Generally, if a mouse button quits working, it requires the replacement of the touchpad assembly.
Boot to the safe mode, see if the button works there, if it doesn't, then it is a failure of the switch in the button
http://cgi.ebay.com/TESTED-Sony-Vaio-VGN-NW150J-LCD-Keyboard-Palmrest_W0QQitemZ120522991092QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item1c0fbae5f4#ht_1088wt_1165
SOURCE: how to check mbx-160- vaio
I HAVE A SONY VAIO LAOTOP VGN-N31S DO NOT START UP. LED LIGHTS ARE ON. SCREEN IS DARK. CAN ANYONE HELP
Different drive. Going from HHD to SSD. Do I need to change the BIOS to AHCI and at what point?
Na, cheaper than a new computer. Thanks
