SOURCE: Only First Phone in the system will ring on incoming calls
No the manuals locates on the norstar website are just the tutorial telling theat hte hold button put a person on hold...we all know what the function of a hold button is or even a line button is...if someone has some real information please submit it! Oh and i have already tried calling norstar...they tell you to call meridian, then meridian tells you to call norstar...great customer service!
SOURCE: M7310 phone not ringing audibally
If the internal calls dont ring, then there is something with the extension. When a call is ringing the phone, press the UP VOLUME. Chances are that someone accidentally turned the ringer all the way down.
Let me know if that doesnt work.
SOURCE: No ring and appear on my Norstar M7310
This should work on M7310, M7324 & T7316
Feature ** 266344 - password 266344 - configuration - line data - line access - show ext (yours) - line assignment ( which lines you have, usually 1 & 2) - show line - appear only/ring/apprear and ring
Hope this helps
SOURCE: phone wont ring on incomming calls?
Could be two things, first is DND or do not disturb. Make sure that its turned off by either pressing the DND button or feature #85.The second is that the ringing wasn't turned on in programming.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should sat line 001: appear only press CHNG til it says appear &ring.
press next key (lower right arrow)
The display should say line 002: appear only
Repeat same procedure as line 001 til all available lines are done
press the release key when finished
SOURCE: how can i change my extension nuber (norstar M7310)
Sorry can you clairify this question...
-> You need a new extension number for your set?
-> You need a new extension on your set so you can see when they are on their phone?
If it is the first, there are many things that you need first, too much to explain at the moment. But you need to have the password and a template for your phone to make changes.
If it is the second, press:
- Feature * 0 and any button to find out what is on the button, look for an empty button or one that you want to overwrite,
- then RLS,
- press FEATURE * 2
- press the button where you want to add this new extension
- dial the extension of the new person
Voila you are done!
