A power surge most likely damaged your printer. Printers are a cheap item and getting it repaired would most likely not a cost effective solution. To prevent power surge problem you need to connect all your computer equipment and printer to a power board with a built-in surge protection then plug this power board into the mains outlet.
The code that is flashing usually points to a main board failure. I would recommend getting it diagnosed. If you want to be gutsy and try and replace the main board yourself, MAKE SURE YOU GET A BOARD THAT MATCHES YOUR PART # EXACTLY. Sharp makes several revisions of main boards for various models, and they ARE NOT compatible.
Check If the old batterys did leave oxidation or battery fluid from leaking , could Cause bad connection, as the got Very hot , or 2 check If the New batterys are ok ,
You should set the white balance to an appropriate setting. For outdoors, or indoors with flash, auto +-0 should be adequate. For indoor work without flash, try the incandescent (light bulb symbol) or fluorescent (strip light symbol) if you don't like the results from auto.
