Watches Logo
David Jenkins Posted on Apr 04, 2012
How do I set the second timezone on an invicta russian diver 10008?
4 Related Answers
Anonymous
  • 2071 Answers
  • Posted on Jun 17, 2008
SOURCE: how to remove links on invicta russian diver watch
Hi Pate the only thing i can advice you is go to a service center near to your place.All watch technician like me have the knowledge to remove the links with no impaired damage or scratch.We know how to detach the links.So if want to know more of your watch i will give you a site that can help you and ask more information about your watch. www.invictawatch.com
Anonymous
  • 110 Answers
  • Posted on Nov 19, 2009
SOURCE: What kind of battery does the Invicta Men's
The correct answer is to examine the battery that is in it and identifying the markings on the old battery. To do this you will need of course to remove the case back. Now if the watch does not have a battery in it then that is another story. Sometimes you will see the battery type marked on the inside cover of the case back. Hope that helps, Best of Luck
ginko
Ginko
  • 19396 Answers
  • Posted on Oct 19, 2010
SOURCE: invicta #0564 russian diver large
Hi.
As you probably expect, replacement parts for the watch cannot be directly purchased directly from the Internet, choosing from an online part list.
You will need to submit a service case to Invicta. Here the page.
The only other option is finding a local repair shop.
Regards.
Ginko.
Anonymous
  • Posted on Nov 28, 2010
SOURCE: GOOD EVENING, I HAVE AN INVICTA
ok if u mean sizing the watch ok veyry easy just pinch 1 side of the link where u are sizing and with a flat head micro screwdriver un screw opposite side now i would so this to all screws as they get very loose in normal wear put a lil bit of lock tite on eack screw and put back 2gthr after u have sized it hope this helps i have an rs8 took me less than 5 min to do 2 watches green and purple
Need help winding an Invicta 14214 russian diver automatic
once you have removed the screw down cap there is a smaller crown , looking at one of these before the smaller crown can need a bit of a tug to pull out maybe even a pair of pliers.
Need a replacement band for Invicta Mens 4578
with the model number you should be able to find one easily on ebay or amazon. ask the seller any questions before purchase if unsure.
How do I wind my Invicta 1805?
My very brief research shows that the Invicta 1805 watch is driven by a Japanese quartz movement. That would certainly explain why you're having trouble winding it.
The easiest check for quartz vs. mechanical is to observe the second hand. If it pulses only one time per second--i.e., jumps one second at a time--then you're looking at a quartz movement (I'm ignore the rare and expensive mechanical jump movements). If it looks like the hand takes 4 or more little jumps to get from one second to another, you have a mechanical movement.
Need setting intructions for invicta russian diver watch 4898
Thank you for contacting FixYa. You can download at the following link:<br /> <a href="http://invictawatch.com/welcome/manuals/">http://invictawatch.com/welcome/manuals/</a><br /> <br /> Best regards.
I own an Invicta Russan Diver Model #4578 and I nee replacement screws for the rubber strap. Do you know where I can find them ?
mcdevito75 here, I would contact shop NBC for info, here is their contact number, 800-474-6762 They should guide you to Invicta parts.
4helpful
Bought this Russian Diver 7003 from ShopNBC about 2
Hard to fix for people without watchmaking knowledge. I'd do that in 15 minutes. Anyway - Invicta is NOT even the average quality watch company, so, can NOT charge you more than price of watch. Contact me: [email protected] This will be long explanation, but , hopefully you will get it right.
What kind of battery does the Invicta Men's Russian Diver Watch take?
5helpful
How to remove links on invicta russian diver watch
Top Invicta Watches Experts
Ngoro
john h
Are you an Invicta Watch Expert? Answer questions, earn points and help others
