Had a similar problem on my cali ev. It turned out to be the battery. Once replaced with a varta fun start it's been fine. That was nearly 2 years ago. Good luck..
In fact only turned over once befors starter was clicking away. Pushed it home tried again - nothing. Put battery on charger - charged up in 15 minutes - tried to start - engine turned over couple of times then click click click at starter been out this morning checked all connections and earths - charged battery up - read 13.22v when full charge light came on, tried to start up - turned over several times, getting slowwr then click click. Checked battery reading 12.17v Any suggestions - is it the battery or what else?,The fact that the voltage drops as the revs increase is very odd. However, the dash voltmeter which I assume you are using is often inaccurate. Try an alternative battery, at least to see if it starts. You could use a car battery with jump leads. With a decent battery the charging might improve too.,,,
SOURCE: electrics
in fact only turned over once befors starter was clicking away. Pushed it home tried again - nothing. Put battery on charger - charged up in 15 minutes - tried to start - engine turned over couple of times then click click click at starter been out this morning checked all connections and earths - charged battery up - read 13.22v when full charge light came on, tried to start up - turned over several times, getting slowwr then click click. Checked battery reading 12.17v Any suggestions - is it the battery or what else?,The fact that the voltage drops as the revs increase is very odd. However, the dash voltmeter which I assume you are using is often inaccurate. Try an alternative battery, at least to see if it starts. You could use a car battery with jump leads. With a decent battery the charging might improve too.,,,
