Can you take any parts from a working Northstar 941 and use them to fix a non powering up 951?
The 951 worked one day and the next day would not power up / even after checking all ok power supplies externally.
What is the most likely cause for this loss of power after everything outside of the unit checks out?
Thanks for the Help!
Engine HP, deck width, tire size, hydro drive... all same/similar. Likely insignificant design changes (non interchangeable parts).
These are intended for small suburban <2 ac.
It should work for DSLR as long as the release plate will fit your DSLR camera. Most screws for the quick release plates 1/4 x 20 screw. Larger cameras and those with larger lenses need a bigger screws...making some plates non interchangeable.
