Was given an older Necchi 3537. The bobbin thread will not catch & pick up.
SOURCE: 6022 necchi sewing machine
There is a site that has instructions with how to thread the machine properly. Click here for the www.sewusa.com threading section
SOURCE: no instructions how do you tread the machine?
Just go to this site: www.sewusa.com They have threading guides for free. They are the main importers for Necchi in the USA (from what I understand anyway).
SOURCE: Model 3205 FA not picking up bobbin thread, needle
- check ifu are using same needle model.
- check hight of needle bar is ok
- check timming between needle bar and hook.
- check if your material is very stritch or no
- check blad point of hook is ok or no
best regards
SOURCE: NECCHI, model 4795. Thread bunches up at bobbin.
it sounds like the thred tenshion is to loos or the timing has sliped a little and its off a bit this can also happen with wear on the gears or just a loos fixing letting the timing slip back a bit,
