Generac Power Systems Generac 5793 Ix 2000 Watt Portable Inverter Generator Logo
A
Anonymous Posted on Apr 02, 2012
Generac ix 2000 does not start. checked spark plug and it is good. oil good.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 05, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
3248
Points
What a **** generator, worked for 100 hours and now wont start anymore.
did all the checks and replacing of spark plug and oil etc, simply wont start, ****, ****, ****..... service is horrible too. they just give you the runaround.
Why isn't it producing rated output?
Rated output is at full load. Units will produce power up to that limit and use gas accordingly. Very lite load = less output and less gas consumption, etc.
Generac ix 2000 mod 0057932 start up ok but then stops running
Possibly blockage in fuel tank or line to carburetor? Fuel filter?
Fuel turn off valve? Generator malfunction that pulls the kill switch?
Owner's manual trouble shooting?
No manual try for owners and repair manual http://www.manualslib.com/
There is no spark to the plugs on my generac 12000 watt generator,i replaced the plugs and still no spark,any help would be appreciated.
Unplug the oil sensor.
The oil sensor is located behind the oil filter. I unplugged the oil sensor and it fired right up. Plugged it back in and it runs fine.
It might be because it is cold.
I don't know why but I turned it off and it starts right up now.
1helpful
Ix 2000 surging
YOU NEED TO AJUST THE FUEL MIX ON THE CARBURTOR
1helpful
Generac 5793 Ix 2000 surging
It sounds as though there is an issue with the carburetor. If the unit is "surging" with no load I would recommend thoroughly cleaning the carb. It would also be a good idea to test the fuel pump. Per Generac you need to disconnect the fuel line leading to the carb and pull the starter rope over to see if adequate fuel is flowing. If none of this is the issue try testing the stepper motor on top of the carb. If you unclip the wire and use an OHM meter all wires should test at 150 ohms. to test place on test lead on the blue wire and move the other lead to the remaining four wires. The should all ohm out to roughly 150ohms. if this is not the case you need to replace the stepper motor.... Before you do any of this you should check for fresh fuel, a good spark plug, and proper compression.
Top Generac Power Systems Electrical Supplies Experts
john h
CJ Rock
CJ Rock
Are you a Generac Power Systems Electrical Supply Expert? Answer questions, earn points and help others
