Printer will print photos but will not print anything from Yahoo or web sites. It prints "printer language" I was told. Pages and pages of small type makes no sense.
You might want to try using the HP Smart Print.
Click HP Smart Print to download and use it.
SOURCE: My Brother MFC 9420 CN
Click HERE! and download the pdf document!
You have all the instructions needed to solve the problem .
SOURCE: Printing stops on its own after printing a couple
SC285 is a line position adjustment error. It is possible the ID sensors are dirty. In order to get to them you have to remove the PCUs and developers as well as the transfer belt assembly. The sensors are behind the shutter that is next to where the upper most PCU would be inserted.
SOURCE: I have a networked hp 2025dn printer the problem
my personal opinion is that you might have two basicproblems
1.open the lid from back of your printer, you may see a stiff film .,give aprint command and check the film rolling visually , if its broken then it mightgive you annoying sound like something's broken , but it can only be visualizedgiving a print command ,
if its really broken from edges it may give you this problem, it can be fixedby local service center ,I had this problem it cost me about
2.(clean your printer )
>Open printer
>remove the toner
> check for any piece of stapler pins or any paper or anyother waste that's stuck in between drums.
> if you have a wind blower machine blower it .
> must keep in mind to blower it in open area, causeblack particalls will make you cough, or would get dusty,
3. your toner must have ink dust at one side, shake thetoner and then insert in printer , this will help you .
I hope it helps you
SOURCE: I have typed text using ms word 2007 of about 5
do you still have inks left?are you able to make color copies from the printer?
if your answer to both questions is yes then you may have junk files on the pc that's blocking the printer.
try printing in notepad or in wordpad.
if you are able to print from those,then the problem is with ms word's settings.
if not,click on start,in the run or search box,type in disk cleanup and hit enter.a box will come up after disk cleanup is done with calculating how much space you will be able to free on C drive.tick all the boxes and hit ok.
