Brand new card not formatting
Go tinto the camera's menu and format the SDHC memory card.
If this does not work then insert the SDHC memory card into an USB card reader and plug it into the USB port on your computer and it the computer detects it as an external storage device then format the SDHC memory card.
If the computer cannot detect this SDHC memory card then this memory card is faulty.
SOURCE: will a SDHC 4G card work inthe c875 camera ?
i don't know if you got my last post (pc playing up,im not going to tell you its the user :))
the answer is no you can only use upto a 2 gig card on this camera
(did a search on the kodak website then phoned them up for you and that's their answere)
SOURCE: memory card error after inserting SDHC card on powershot A620
the a 620 only goes up to 2 gb no higher
SOURCE: I just put a brand new 8GB Sandisk SDHC card in my
Guys you have to have the camera format the SD card itself for best results and compatibility.
SOURCE: cant get sdhc card to format with kodak eashshare cx7430
Your camera has no support for SDHC, only SD - this in essence means you can put a maximum of 2gb card.
Good luck.
SOURCE: Memory Card
Hi...
The way to format is just follow this, you just plug you camera to the computer then turn it on, after that, the camera will detected, you open my computer, you can see the removable disk, just right click then format then check quick, then ok
Good luck !!!
Regards
PCmania
