WHERE HAVE THE ICONS GONE FOR SOME OF MY INSTALLED APPS? iPad works fine in most respects but unable to access SOME installed apps as no icon appears for them on iPad. Lack of icons also means unable to uninstall these apps for possible re-installation. So, I'm stuck in a cleft stick!
When you exceed your allowed pages for apps,they will still install,but app cannot be created for lack of pages.You can get more room by grouping similar apps into 1 folder to make space.You can also use search function to fill any app installed.Scroll all pages to right until keyboard appears,then type name of app,it will appear in dropdown list.
Please Rate
Here is what you need to do. First, make sure the icons aren't on another page. Swipe right on you main screen to make sure. Another possibility is that you have restrictions on which are hiding the icons. Go to Settings > General > Restrictions. If it asks for a 4 digit code, you have some restrictions on. If you know what it is, enter it. After you enter it, you have two options. You can either press the "Disable Restrictions" button, or you can go down to where it says "Allowed Content" and click Apps. At that point, make sure that "Allow all apps" is check. That should fix the problem. If not, you should reset your ipad. You can do this by holding the Home and Power button simultaneously. Let go when you see the Apple icon appear on screen. This may cause the icons to reappear. Hope this helps.
I'm tring to get free apps and there asking for money never did that before
SOURCE: all of a sudden the icons are too big and don't
I believe that you may have the accessibility mode turned on. I think if you double tap with three fingers it should return to normal.
- hold on to the icon that you wish to uninstall.
- After some seconds continous pressing, the App icons will begin to shake.
- Then tap the close button which will be denoted by 'X' symbol on the top left corner on one of the icons you wish to delete
- You will be prompted whether to delete the application.
- You will have to click on the delete button.
- If you wish to re-install the application later again, you will have to go to the App Store and then download again.
How to Delete Web Page Links on the iPad
- After some seconds of continous pressing, the App icons will begin to shake!
When i go to gmail on ipad it takes me to "welcome to mail". The icon is not letting me into my acct
screen frozen on candy crush all icons are gone
when i open app store a lot of icons show up. I cannot load an app of my choice or the icons showing
Duolingo app microphone not delivering messages
