It is the outside of the door glass that I need to replace
Click on this to view the diagram.
Put a thick towel on the counter (or table). Remove the door from its hinges and set it on the towel. Be careful not to damage anything, especially glass and door handle. Remove the door handle (#10 screws). Remove the bottom screws that hold #4 outer panel to #9 inner door panel. You can then set the outer panel aside. Collect broken glass pieces if any and install the new glass. Set the outer panel back on, and repeat the other steps in reverse.
That's about it.
Let us know how it goes...
Thanks
SOURCE: how to take apart oven door
you need to remove the door. On your model just grab the door and lift and it should lift right off. Then remove the screws that run along the bottom of the door. Remove the bottom trim and the glass should slide down and off. Reverse to assemble
SOURCE: GE oven door
First, determine what this gook is. If it is grayish, it is ash and can be removed with a rag and plain water. You'll always find ash as a byproduct of the cleaning. If it seems to be oven grease and is located in the gasket or gasket area ONLY, get some WD 40 and spray it on the gunk. Let it loosen up and remove it with a rag. You may need multiple applications. If possible, follow up with a soap solution to remove as much of the WD 40 residue as possible. Note, this may cause some smoking when the oven is next cleaned. Be sure to ventilate the area well while using this or any other solvent. Do not use the solvent on glass, it may discolor when heated. Use a standard glass blue liquid glass cleaner or water. If the glass won't clean easily, you may use a WET mild abrasive pad or steel wool VERY gently...so as not to scratch the glass. Follow up with a dampened rag. Anything you leave on the glass will be baked on...so make it clean! You may also use this procedure in the gasket area on the porcelain. Porcelain is a glass-based paint. It should not be scratched. Be patient.
Be aware that if you take door apart that the door is counter balanced. Removing a significant amount of weight by taking off pieces of the assembly may cause it to slam closed. Each of the two thicknesses of glass are mounted separately. Usually, there are some kind of clips holding the glass. Note that there is often fragile insulation inside the door. Avoid touching it or breathing in any dust it may emit. You may need a second pair of hands to align the door front and the bolt holes when re-assembling.
In the future, do not wait too long between cleanings. Use a rag to remove heavy spillage as soon as you find it, don't wait for a cleaning cycle. If your oven is very dirty, use a 3 hour setting or longer to finish the job if you have goo left in your oven after the cycle.
Bob
SOURCE: glass on front door of
If its not too old, try sears.com
They carry many parts and if not there try apwagner.com
SOURCE: Oven Door Inner Glass Replacement
can you gals get me the complete model # off the stove and i will look up the parts diagram & exploded view.
SOURCE: Can't remove oven door from Whirlpool model GR450LXH
the hinges problably require to be "locked" beforer removing from door frame, usually explains in hte manual "how to remve door". if needed, you can input your model number here, to download a copy
http://shared.whirlpoolcorp.com/product_literature/literatureSearchResults.cmd?siteCd=WHRCOM
