Question about Motorola Mobility CLIQ Cell Phone
Cliq blinking white light
Phone wont turn on.... nothing happens switch battery's, charging by wall or computer, holding different buttons down, touchscreen, just nothing... its completely dead except for this blinking white light top right of phone. will i be able to save data like pics,contacts, etc.., if phone is fixable if that
Htc wont turn on and 3 lights are blinking on the bottom front..
Ok this happens when kill your battery..............Turn phone off and let it charge for a long time (maybe 20 mins to an hour) then power on with a long press of the power button, wait a bit as this process can take a while.
It may be that the battery will never come good again in which case you will need to replace it.
Also the one X does have a hard reset, hold the power button til the lights at the bottom start flashing, then keep holding til they go off. Then, let go of the button. If it's not broken, it will turn on and boot normally.
NOTE: When charging via USB it is possible to use more load than the USB port can supply, if this happens your phone will never charge.
To be sure Turn Phone Completly off and charge via a wall socket..
Nov 03, 2013 | Cell Phones
Roomba 4220 light says charged but wont turn on
Try resetting
to reset the charging system. You can do this by removing the battery from the robot and unplugging the charger from the wall and robot. Please hold the power button down for 30 seconds. You then should charge the robot....."
Dec 29, 2012 | Vacuums
My htc freestyle wont turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Nov 05, 2012 | HTC Freestyle Smartphone
Tx-26lxd70a tv wont turn on
5.Wait 10 seconds.
Step
Thanks
Aug 12, 2012 | Computers & Internet
How to unlock my tmobile motorola cliq
Call T-Mobile at 877-453-1304 and request the unlock code for your CLIQ from a customer service representative.
  • 2 Slide your CLIQ's battery cover away from the camera lens and off of the phone, and then lift the battery out of the battery compartment and set it aside.
  • 3 Slide the T-Mobile SIM card out from under the metal band holding it in place, and then place a SIM card from another carrier in its slot.
  • 4 Replace your CLIQ's battery, and then hold down the "Power" button on the right side of the phone to turn it on. Your CLIQ will prompt you to enter a special code.
  • 5 Type your unlock code using the number keys on your CLIQ's touch-screen or slide-out keyboard.
  • Feb 27, 2012 | Motorola Mobility CLIQ Cell Phone
    I phone wont turn on
    This will happen when the battery has become completely drained. Plug it into the wall using the A/C adapter and allow it to charge for a while. If it still won't power on, hold the sleep button (on top of the phone) and the home button for about 5-6 seconds for a soft reset. When you plug it in you should see the symbol of a drained battery on the screen as it charges up.
    Nov 23, 2011 | Apple Cell Phones
    My iphone 2g wont turn on, i replaced the lcd, it worked ok, my batter was low. so it died and i was trying to turn it on, but it wont turn on. when i plug in the wall charger nothing happens,but when i...
    I have a feeling that when you ran the battery down it is now struggling to get and hold a charge.
    If you have a friend with a similar battery perhaps try that, or go to a mobile store and ask them to try a new battery for you.
    Nov 09, 2009 | Apple iPhone 3G
    My flip video camera froze.it wont turn on....
    Have you tried resetting the camera? Hold down the power button and the red button simultaneously until the camera shuts off (takes about 10 seconds). Then, just press the power button again and the camera should turn back on. I had the same problem; when I pressed the red button to stop recording, the camera froze, and the red light remained on. I tried resetting it like this, and it seemed to work.
    Jan 19, 2009 | Pure Digital Flip Video Ultra Camcorder
    Uniden cordless phone
    I found that if I hold the "find hs" button on the BASE unit (right above the red charging light) for a few seconds, it works!! Thank goodness there is a solution! Thanks for the help.
    Feb 07, 2008 | Uniden Cordless Phone
    Motorola Mobility CLIQ Cell Phone Logo
    99 people viewed this question
    Top Motorola Mobility Cell Phones Experts
    vince
    D. E. Hev
    Mark Magill
    Mark Magill
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
