Question about Acer Computers & Internet
Cant get to boot screen to start recovery on e525. I tried every f key! Only get e logo screen which will flash to a black screen with blinking cursor at top left then flashes to all black screen back to logo screen. It just keep repeating that over and over
  • 392 Answers
You can follow the solution provided by Achalesh Prem P or you can zero fill your hard drive
Posted on Apr 02, 2012
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 135 Answers
Some of the emachines coming with Recovery image. You need to press F11 key on starting to check whether the image is available or not. If it is there proceed with restore.
Otherwise you need a recovery CD to do this. If you don't have any CD then you could purchase the recovery disk for your emachines from the link below by entering the serial number on your computer:
https://secure.tx.acer.com/RCDB/Main.aspx?brand=emachines
SOURCE:
  • 8 Answers
SOURCE: computer displays black screen with blinking cursor
Its seems its not booting correctly. Just Insert Windows CD and fix the windows. Another solution is to press (I think) F1 or F11 or F12 (depending on the model) when booting the machine. It will take you to recovery mode. Use it to restore the boot section ONLY.
Posted on Mar 06, 2009
amstyl
  • 62 Answers
SOURCE: My Asus eee PC fails to boot
Reboot the system
Press F8 at boot startup. In the boot menu
Choose Last Known Good Configuration. If this doesn't work
Try Safe Mode
Go to Device Manager
Roll Back any new driver you've installed
and/or
Go to Add/Remove programs
Unistall any new software you've installed
Posted on Mar 31, 2009
  • 47 Answers
SOURCE: black screen, blinking cursor in top left hand corner
Could be a number of issues, incl unseated processor or a faulty hard drive. First off I would remove mains & battery, remove covers from underneath and reseat any memory or processors you can find - by reseat I mean just take out and put back.If this fails, I would look to price up a new hard drive before condemning the machine.
Posted on Apr 28, 2009
SOURCE: won't boot
I had this too. It kept happening after I would install updates. I think the problem turned out to being that my harddrive (only 4GB) had run out of space.
The way I ended up fixing it was to turn the power off by holding down the button, turn it back on and hold the F9 key. This allowed me to "restore factory defaults" and it booted up again. I lost all the changes I had made, so if you had settings saved, this may not be your best option.
If it is a harddrive space issues, I would recommend getting to the console (CNTRL+ALT+T) and then typing "sudo synaptic" to get to the package manager. You can then remove packages that you no longer need or want to use (like the kids games, possibly Skype). This stuff is a little advanced, so if you're not sure of what you're doing, you may end up changing something you didn't mean to and needing to start back over again by restoring defaults.
Posted on Jun 17, 2009
RescueTechLA
  • 2653 Answers
SOURCE: gateway mseries laptop won't start, screen black
It's flashing because it's trying to load via the hard drive.
What have you tried so far?
Safe Mode, boot cd, etc?
Posted on Jun 19, 2009
Emachines e525 says no bootable drive
Boot to recovery mode and do a startup repair, if it doesn't help, you can either do clean install or talk to a specialist
Apr 19, 2014 | eMachines 15.6" E525-901g16mi Laptop Lcd...
In recovery mode and lost power, then battery went dead. Now turn laptop on get the ASUS logo , in center, and Intel Logo, lower right corner, on black screen. Then black screen comes on again with...
Take disk out. Power down. Restart. See if will start up without a disk in it. Might be confused by your disk. Did you try to F8 or F9 while restarting to get into BIOS (trying to remember which one will boot you to BIOS). Then see if the CD/DVD was disable for boot up. Turn that back on if you can get into BOS so it will boot up you recovery disk.. If your OS is completely gone, you will have to reinstall...
Sep 24, 2013 | ASUS K Computers & Internet
I have a Coby Netbook Model NPBC1023XPPUR. When it starts up, the Coby introduction screen comes up and then goes to a blank black screen. What can I do to fix this?
First, Cold-Start the machine, unplug, remove battery, hold down on.off button for 30 sec., leave battery out, plug in try to boot normally, is the HDD led blinking? OR, System restore/recovery. At the Coby logo screen appears, press and hold the F7 key to start system recovery, follow instructions. OR remove HDD test, replace if necessary.
Nov 18, 2012 | Coby Computers & Internet
I got a toshiba satellite pro a100 laptop (psaace- 007002en) second hand and it still has lots of the previous owners files on so I would like to restore it to factory settings but i don't have the...
To start the systemrecovery:
  1. Restart the computer.
  2. When the Computer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available orfails, recovery of the Operating System will need to be from Recovery Media. Ifyou do not have a set of Recovery Media, you may purchase the set onlinefrom the manufacturer. Note: If your computer does not havean internal optical disc drive, an external optical disc drive will be requiredin order to recover the Operating System using Recovery Media.
  2. When the computer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
  3. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  4. Close the CD-ROM tray.
  5. Refer to on screen instructions to select either CDROM or USB CDROM.
  6. The computer will boot from the Recovery Media
  7. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
Note: Ifthere are multiple Recovery CDs, please insert the first of the Recovery CDs.
  1. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Sep 20, 2011 | Computers & Internet
One minute it was working fine, the next it was a black screen with the cursor blinking in the upper left corner. I tried re-booting it, but it just goes back to the black screen with blinking cursor. Any...
Are you getting the Acer logo on start up? If so you might have a software issue on the hard drive, or the hard drive itself is defective. I suggest using your recovery disc to re-install windows and drivers providing you have them.
Dec 18, 2010 | Acer Aspire One PC Notebook
I have a Acer Aspire 5745 (CPU: Intel i5 processor 2.5GHz RAM: 2GB OS: Win 7 Home Basic) which is only 2 months old. Yesterday I started a installation setup of a game, when suddenly the system restarted....
Hi, I do apologize for the inconvenience you have been facing.The reason why the laptop does not reboot to Windows even after reinstalling Windows is because the issue is with the hard drive not being recognized the reason for which you get a blinking line on the screen after the Acer logo .In this case I would suggest that if the laptop is under warranty please contact the Acer Technical support and have an order placed for repair.
Thank you for your time and best wishes for your effort.
Nov 19, 2010 | Acer Computers & Internet
Acer ZG5 lsass.exe
Use another computer to copy the files from the CD over to a USB flash drive, if you have got one. Then start up you Acer and go into the BIOS settings (press F1,F2 or DEL a few times before the windows logo appears) Then go to boot device priority or something similar, and choose the priority to boot from a USB HDD higher than your Hard drive. Just to be sure, put it as number one. Save the settings and exit, and restart your computer with the USB flash drive with the files inside in your computer.
Jul 23, 2009 | Acer Aspire One PC Notebook
My computer cannot boot up
The boot partion is damaged,You will either need to get the install disk and run the recovery or get a tool disk with fixboot,scandisk,etc...Or if you can tap F8 while rebooting and start in safe with command prompt,You can try a few things,
  1. SFC/scannow
  2. fixboot c:
  3. Chkdsk
  4. fixmbr
#1 is the system file check
#2 is for fixing the boot partion
#3 Checks the hard disk
#4 Fixes the Master boot record
Please take time to rate this fixya
May 13, 2009 | HP Pavilion A610n (PC106A#ABA) PC Desktop
Computer displays black screen with blinking cursor
Mar 06, 2009 | Sony VAIO VGN-CR220E/P Notebook
Toshiba EA60 laptop wont go in boot sequance, its stop after toshiba logo and gives a black screen with blinking curser in top lef corner
Its probably not the BIOS but the board warping beneath the CPU Socket or similar.. Dont flash it (BIOS) or it will probably kill the chip. Let me look up the model number...
Feb 12, 2008 | Computers & Internet
Computers & Internet Logo
211 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
