Plz solve above subject error code in IR 3300
The error code E0019 is the waste toner bottle is full you need to empity out the waste toner bottle and make sure the neck of the bottle is totaly clean and clear, a sensor reads dirt on the neck that the bottle is full. To clear that code after cleaning the waste toner, turn the main power switch off on the right side of the copier. The waste toner bottle is on the left hand side toward the rear of the copier and is held in with one screw. The E00225 deals with the scanning lamp. you will have to replace the lamp and the lamp PCB as a set to solve that problem. Good Luck...
Worked great, the overflow bottle is under a cover on the lower left side. One screw and its out. emptied the bottle, blew out the sight cavaties and away we went.
Thanks
my photocopier ir 3300 showing error E00100-0002, what do i do
