Hi
i need tv codes for a GE universal remote RM24912
i need the tv code for a NEC tv (i know its a really old tv)
please email them to me at
[email protected]
this would make my life alot easier.
thanks!!!!
SOURCE: Finding a code
What is the model number of the Apex TV you are using this remote for?
The CK5G-C1 remote was supplied only with model AT3208S TV. It will require no code when used with that model. If trying to use it with any other model TV, you can try the other Apex TV codes found in the AT3208s user's manual that can be found in .pdf format at : http://www.apexdigitalinc.com/manual/AT3208S.pdf
Let me know if this helps, or I can be of further help.
In any case, good luck!
SOURCE: Akai LCT3285TA 32in cant find 4 digit codes for tv?
all in one
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
SOURCE: code for apex tv through philips universal remote
Go to www.urc.philips.com/
Follow the steps..its easy. It will ask for the model of your remote which you will find where your batteries are located..The code I used for my APEX tv was 0023.. to load the code first hold the setup button until the red light stays on..then press tv or whatever mode you are setting up..then enter the code and if the red light goes off it is the right code and you should then press channel up to see if it works...If this code doesn't work the site above offers other codes.. Hope this helps!!
SOURCE: Need code to program universal remote for my Apex LCD TV
i have apex tv 2003 and i need a code for my remote
SOURCE: NEED CODE FOR APEX TV
Hello 10156, 10748, 10765,
Remote codes for Apex tV with Direct tv RC-32 model remote control are:
10767, 10879
OK.
Hello, Micheleleo - Unless you want to receive a lot of spam email, please use the Edit feature and remove your email address from your question. No responsible Fixya.com answering volunteer will answer your question with an email.
