It might be good to have someone who does valve repair come to take a look at it. There could be a problem with your valve that might need to be fixed soon. If I were you then I would call a valve repairman very soon so that I wouldn't have to worry about it too much. http://www.johnvalves.com.au/valve-repairs
A "chattering" pressure washer pump can be caused by many things. You could have a bent or damaged inlet line, or the water supply might be too low. Fixing these is simple, but checking on the water supply is critical. Never let the water supply run low for any extended period of time. Other causes of a chattering pump include water that is too hot, you may have air in the pump system or a stuck float valve. A power washer pump that is vibrating, but not chattering could be the result of air in the system or debris stuck in the valves. Catching these pressure washer problems early and knowing what causes them will save you a trip to the repair shop, especially when it comes to the low-water issue.
Troubleshooting Low Nozzle Pressure
Low nozzle pressure is a common complaint generally caused by one of the following:
1. Plugged nozzle tip.
2. Inlet screen plugged.
3. Insufficient flow in gallons per minute (not pressure) to the pump.
4. Unloader valve stuck open due to debris lodged under the check valve ball.
5. Customer use of shutoff-type quick connectors.
6. Plugged hose.
Troubleshooting Pressure Washer Soap Injector
When a soap injector is not working properly, the problem is generally fairly easy to isolate. Check the following:
1. If you have interchangeable tips, make sure the Black, soap tip is installed. Soap injectors will not work when high pressure nozzles are installed.
2. Be sure that the soap injector valve is turned on, and turn selector valve to desired setting.
3. A piece of debris may be caught in the injector valve, injector ball valve, or orifice. Disassemble and clean the injector.
4. If you have an adjustable nozzle, be sure it is in the low pressure position(away from the gun) to draw soap.
Thanks
