It would help if you said where the paper jam was. However the fact that it was ok until you cleared the jam indicates you have knocked something out of place. Its just possible one of the high voltage contact springs that touch the drums has stuck in and no longer makes contacts with one of the drums. Make sure all the semi circular springs move in and out freely. Also check the led heads in the top cover. Make sure all the cables are seated in the heads ok. Make sure all the heads are in the same position and one has not turned around. Retrace your steps as your drums seem to be problem.
SOURCE: OKI C3200N laser printer, low toner problems
For each toner there is an individual toner sensor. There is a real good possibility that the metal contacts on the sensors have become dirty. Typically, a little bit of canned air directly on the sensor contacts will resolve the issue.
After removing a toner cartidge, look to hte left side of where that cartridge rests. The sensor is located there.
SOURCE: When I print to my Oki C3200n the paper comes out
The "fuser" uses heat to "bake" the ink onto the paper.
Your printer seems to have a mechanical problem while "feeding" the paper from the "input" tray, through the printer, passing the fuser, and to the "output" tray.
Check that all the rollers that "pull" the paper into the printer are working -- if one of them is not grabbing the paper, the paper "slews".
If you need help, take the printer to a qualified technician for repairs.
SOURCE: MacBook Pro will not recognize drivers for OKI C3200N
Driver download link: Oki C3200n Printer Driver
SOURCE: OKI c3200n "COMMUNICATION ERROR"
try switch off, unplug, hold up and down & reset button at the back, swith on
omg i do 2
When I print, I get this error (open front cover, 391:Paper Jam) and after printing 2 pages I have to open and close the front cover to continue printing. How can I solved this problem.
