I can not remove write protection from sandisk cruzer blade 16 gb
SOURCE: my sandisk cruzer blade 4GB
if you will look into the side of your SD CARD. theres a small toggle switch there. just slide it to the other side inorder to disable the write protection
SOURCE: Lost space in my Sandisk Cruzer
I had the same problem. Just go to Sandisk's website and download the latest U3 removal tool, run it and it will format it back to 7.5 GB.
SOURCE: My laptop is not able
just format your laptop my dear and then use it.......
your laptop may be afffected by virus....
SOURCE: Transcend 8 GB Pendrive showing write protected
Think this write protection error is due to some virus.
Steps to remove write protection for Transcend users
1) Go to download center of the transcend,here is the link
http://www.transcendusa.com/Support/DLCenter
Type the model no. or part of model number you are looking for.
example: JFV30(all alphabets in Caps )
2) Choose other details like product type etc. and search for your product
3)Then select the product which which is most similar to yours from search results
4)Then download the mFormat utility. You will asked for serial no. if you dont have..enter this no. 1456784523
5) Connect your pen drive
6) run the mformat utility and select full format after full format your write protection will be removed. try twice or thrice if you can't correct at first time.
Thats all...
It worked for me and my friends....
Other pen drive users may visit there vendors site and download any fromat utility present there for your model.
once you open the site type in or copy and paste
circuit diagram for scadisk cruzer blade
hope this helps
