It runs fine during acceleration and while driving. However, it sputters and dies sometimes while in park or neutral. If I put it in any gear it will sputter and die immediately (after acting up in park or neutral) without acceleration. I can put it in gear and give it gas and it is fine. If I let off the gas and bring the car to a stop, it sputters and dies. I have replaced the crank and cam sensors, along with the fuel filter. Diagnostics from the computer at Auto Zone says crank and cam pending. Any ideas?
SOURCE: 1991 Jeep Cherokee stalls, dies while running idling will restart
well i would check the tune up i have owned lots of jeeps and they needs tune ups about every 30,000 miles plugs wires cap rotor take a look at them and go from there
SOURCE: Codes P0303, P0451,P0440- gas cap replaced 2X check engine light
PO303 # 3 cylinder miss fire: check ign coil and wires,
PO451
PO440: looks like perhaps something to do with the fuel line change! i would look further into it before traveling far perhaps a really well reputed garage can help?????
SOURCE: when slowing down & stopping 2005 Mazda tribute sputters and dies
Sounds like it could possibly be a vaccume problem, the computer sees that the vaccume has a low pressure and thus fludding the engine, or visa versa, it's seeing too high of a pressure and cutting the fuel comsumption to a minumum enough to make the engine sputter and die.. Does this happen when the cars in Netural or Reverse or Park? Just Drive?
SOURCE: gas not getting to engine
sounds like your fuel pump, normally fuel pumps die gradually not just like that, so best check fule pump fuses first, also i can not remeber if these have a fuel cut off switch, this is normally located arround the fire wall it looks like a red or black rubber button, if you have one you can press that and see if that sorts it, if not then it more than likley is the fuel pump and will possibly need replacing, but check the other things first, better a new fuse than a new pump...hope that helps a bit
SOURCE: My 99 ford explorer cuts out and dies when accelerating in drive
You may have dirty or clogged fuel injectors, may also be problems with the ignition system. Might also check the fuel pressure to make sure the fuel pump is working correctly.
