Wiring problem
shared by 3 users
posted by rowdies on Nov 09, 2008
Our JED8430, Jenn-Air downdraft has a black, red, green, and white wire, but out of the wall only white, black, and copper. What goes to what?
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Posted by jgdula on Nov 16, 2008
I have Red, Black, Green and White from cooktop and White, Black and bare copper from breaker. What goes where?
Posted by dwsmithok on Nov 12, 2008
same problem matching up the wires from the outlet to the wiring harness on the stovetop
Solution #1
posted on Nov 15, 2008
Thanks for Trying (70)
amelisdad
Rank:Wiz Wiz
Rating: 85%, 111 votes
those wires dont go to the down draft. those colors are to hook up the stove. do you have the instalation instructions?
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on wiring problem:
I don't want to Accept this solution
Solution #2
posted on Dec 04, 2008
Not Rated (0)
rcowling
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
You should double check the wiring at the circuit box, but if it's like mine then black and white are both hot, and copper is ground.
So, connect
Jenn-Air Wall
Black Black
Red White
White Copper
Green Copper
I've just finished wiring up mine like this and it works perfectly.
Thank You!
Can you Help with these Kitchen Cooktops problems?
Jenn-Air JED8430 Electric Cooktop
I need to know how to seperate an existing granite tile...
what would cause the left bank not to work, swich all...
Only the right front (large) burner operates. The lights...
I just found in a two-inch hairline crack curving along...
I have a gas cook top from Jenn-Air..It is abt. 16 yrs old...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Top Repair Providers for
Ranges & Ovens
(410) 609-0006
A Leader In Kitchen Equipment Sales,...
Allegro Restaurant Repair
(800) 555-9987
All the services you need in order to get your...
Home Blue
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
X
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
