It makes the sound that it is printing, the screen says I have almost full ink for color and blank ink
SOURCE: A10A940 Dell Printer
Our black ink quit printing, cleaning did not help. I finally got it to print by selecting:
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
SOURCE: dell a940 all in one printer
hmm..ok..if the test page is good, then it's in the drivers. get new ones, remove old ones first, re install try again.
SOURCE: Dell A960 printing blank pages
I just sprayed windex on bottom of cartridge several times and wiped with paper towel until dark streak of black appeared. Then I dried off cartridge and replaced. It works now. Must have been clogged.
SOURCE: Dell V305W printer says ink is low and it's not!
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
SOURCE: Left side of page prints lighter than rest of page
You should contact Dell about returning these for a replacement, it sounds to me like a manufacturer's error.
