I have replaced the battery, pluged it it and It will not come on automatic. The new battery is fully charge.I checked the use setting and the power setting shows it is not charging. What can I do to fix this?
Have you check the voltage output on your power/charger cord? It's easy to test if you know how to use a multi-tester or take it to a small electronics shop like a Radio Shack.
If there is no voltage output from the charger, then simply replace the cord. I have found that those charging cords can break real easily but it's hard to physically see any damage.
Otherwise, if you've already tried a new charger, you may need to send your GPS in for service.
Some of magellans and other models of GPS car chargers have a replaceable fuse in side the charger end, which plugs into cigar lighter, carefully dissassemble the charge unit and check fuse.
