Philips 42PF5521D 42 in. HD-Ready Plasma Television Logo
Anonymous Posted on Mar 31, 2012
I have a 42 inch philips plasma tv with a broken screen, could i replace it with a screen from a panasonic 42 inch tv
  • Anonymous Apr 01, 2012
    thanks for helping
Anonymous
Level 3:
Top Expert:
  • Philips Master 14,553 Answers
  • Posted on Apr 01, 2012
Anonymous
Philips Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718464
Points
48227
No--this is called a PDP or plasma display panel and no two (even same brand) can be interchanged.
The cost of a Panel exceeds the cost of a new set--broken screen=fatal issue.
5 Related Answers
maatmartin7
matt martin
  • 1259 Answers
  • Posted on Dec 25, 2009
SOURCE: Looking for replacement panel for Philips 42'' model #42pfl5603d
Visit Anrews Elctronics.com. Ask for a salvage part.
Anonymous
  • 17 Answers
  • Posted on Dec 25, 2008
SOURCE: trying to connect nintendo wii to philips tv
If I have the right manual you should connect the wii cable from the package to th backside of the tv. You will see four pluges. Choose with VGA you want to use, this is not important. Use the cable from the wii and plug in two of three pluges, you must match te coulors. If you have a cable box installed you will probably have scart (a big cable with a large head) connect this and it would run smooth. You can also connect the three pluges from the cable to your cable-box, use the red, wihte, and yellow pluge.
Anonymous
  • Posted on Oct 03, 2009
SOURCE: I have a Philips 50 inch plasma tv. The light is
I have Philips 50 inch plasma TV purchased almost exactly 3 years ago. Completely out of warranty. Paid 1999 bucks for it new. Now Plasma TVs similar to this are 800 bucks. I figured the cost of a repair tech coming to the house would be around 500 bucks.. so I decided I could "do no harm" and look at the power supply. Sure enough, two 3300 uF caps were swollen.. I am far from a true electrical repair person, and if it were not for the caps being swollen, would have no idea that they were bad. I am however a little bit skilled in soldering. So I ordered replacements for about 8 bucks. The caps were actually only 1.50 ea. but the min order fee and shipping brought it to about 8 bucks.. I got them from studiosoundelectronics.com . They came in today and installed them... to my astonishment, my TV works as good as it did when it was new... I must say that I am dissapointed in Philips.. and will never buy another product from them. If it is out of warranty.. they will not even talk to you.. I don't think it is too much to ask when you spend 1999 bucks on a product from them.. I expected my TV to have more than 2.999 years in life in it. Thanks a million to this site for providing soulutions for folks..
Jeff
Florence AL
Anonymous
  • Posted on Dec 08, 2009
SOURCE: 42" philips plasma, black screen and flashing red light
This fix was posted on similar problem, worthy of repeating: Replaced 3300mf 10V capacitors at PS. Both had bulged slightly. Upsized to 25V as the previous solution poster had suggested 16V but I could not locate 16V so used 25V and TV is back to normal!
Anonymous
  • Posted on Dec 12, 2009
SOURCE: Philips 42" Flat Screen Plasma - blinking red light 7 times - HELP please!
Here is a photo of the board where I have removed the two from my TV. You can see the two open holes.
How much would it cost for screen on a 42 inch plasma screen
tcp42x3.jpg Panasonic Viera TC-P42X3 42 inch Plasma TV with 2 HDMI inputs
Your Cost: $640.79
  • 600 Hz Sub-field Drive: Yes
  • Image viewer: Yes (AVCHD/MPEG2/JPEG/MP3 playback)
  • Energy Star qualified: Yes
  • HDMI: 2
  • USB: 2
2helpful
3answers
Panasonic LCD TV with cracked screen
Sorry,not repairable,because the LCD,PLasma,and DLP screen are limited produced.Replacing the tv pannel screen will cost the same as a new tv.Might even cost more after the labors.The tvs screen is about 90% of the tv,that why when is broken or damage,now it only use for it electronics boards parts,or sell for it electronics boards parts that it.
My philips plasma tv fell off my stand and smashed the screen. there is sound coming bu no picture. the glass inside is smashed but nothing has run out of the screen. can it be fixed?
Yes it can be fixed most certainly. You have broken your Plasma screen and most certainly scratched your filter glass with the broken screen glass inside. Depending on where you bought the TV, and whether you have a cover plan, you may get the Tv screen & Filter replaced under accidental damage. If the TV is still under warranty and you dont have a cover plan, you may find the repair will be refused. If so, you could maybe buy the same tv off ebay as repairs or spares and fix yours.
42 inches samsung plasma screen with sound and without image
Check this link to find the LJ41-02759A board for your TV. These boards fails quite often and the TV will power ON but with the same symptoms as yours.
4helpful
Panasonic plasma tv (47 inches), inputs not working
My 42 inch is powering on but is blank on the screen ..
Broken glass - 42 panasonic th c42hd18
usually not very cost effective to replace the front screen. id say around 70% of what you paid for the tv.
42'plasma phillips tv
I had the same problem and fixed with a great online tutorial. Just replace 3 capacitors available at Radioshack onthe the board. 2662, 2663, 2664 1 is a 1000uf the others are 100uf. Max Volts need to be over 25. It worked great, check http://dynamicorange.com/2008/06/25/fixing-a-plasma-tv/
for more detail.
Philips Plasma Flashing Red
every plasma tv ive come across with this symptom eneded up beeing a new panel. what i do is replace the x and y sustain boards and if that dont work youll need a new panel.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
