SOURCE: 2003 dodge neon accelaeration
i had a problem like this turned out i had a broken mounting stopping accelerater cable from turning full circuit could be worth checking
SOURCE: I have a diagnostic code
If I remember correctly, P0700 means the automatic transmission computer has a problem and
P1684 means the battery has been disconnected within the last 50 starts.
Hope this helps.
SOURCE: 2002 Dodge Neon
Your starter could be frozen or your battery is strong enough to light the lights just not spin the starter
SOURCE: Starting a 2002 Dodge Neon in extremely cold weather
Turn the ignition key to the run position for 30 seconds and then off for 5 seconds and turn it on to the run position again for 10 seconds and then start the engine. This will pressurize the fuel system and warm up the MAF sensor to burn off any dirt and frost on the filament, you should not have to press on the gas peddle, the Idle air control valve should do that for you. Good luck and this should help.
SOURCE: I own a 2005 Dodge neon SXT. Once in awhile a
The red circle means there is an intermittent problem with your vehicle security.If your car starts and runs fine it would be hard to diagnose until it wont start at all.
