Second new ink cart., cleaned everything, printed nozzle checks, just won't print that color - now what?
Unplugged the printer 2x. On the first try I just plugged it back in and still had the problem. The second time I took all of the ink tanks out, unplugged it (with the power still on, don't know if this makes a difference, but that's how I did it) then plugged it back in. The printer said that it couldn't detect any ink. I reinstalled all ink tanks, and a message said that it had been shut down improperly. Press ok to continue. I test printed a picture with a lot of blue in it and the picture came out true to the exact color of the picture.
That's what worked for me. I hope it works for anyone else with the same problem.
(Sorry for posting this twice. I missed the solutions link at first)
SOURCE: MP830 Cyan Ink won't print
To Fix the stupid Cyan, just unplug the printer, it may take more that one time unplug, its stupid problem, printer needs to reset, I have a full ink of Cyan but it says this "There is more than one Cyan" on the dispaly on the printer, and windows that its missing. I don't know what idiots programmed the printer. but screw them.
for cool stuff check out my site http://www.gagla.com
SOURCE: Canon MP500 Printing Problem
I had same problem today. Removed print head and bathed it in alcohol for half an hour. Then I removed the two screws underneath and used a syringe to squirt alcohol into the ports and clean. I noticed clumps of ink coming out (i guess some ports were blocked). I then dried the head and reinserted and reinstalled ink tanks. All looks good so far- black printing again and printed test patterns all look correct. Good luck.
SOURCE: Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
SOURCE: iP4300 only recognizes magenta OR cyan
1. Get compressed air
2. Run Printhead under HOT water, do not worry about contacts getting slightly wet.
3. Blow compressed air with straw attachment into screens where the cartridge nozzle sits on printhead. then let it sit and dry.
4. reinstall print test page
5. if this fails open paint/photoshop and print a page of the color that is not printing correctly. rinse and repeat until colors flow freely.
I have several ip4300s and I have yet to give up the ghost on a printer with a clog ujsing this method.
SOURCE: Canon MP800 PGBK black ink will
I have the same problem. I turned off the printer, then selected "auto head alignment from the printer's maintenance menu and it worked!
Menu -> Maintenance/Settings -> Maintenance -> Auto Head Align
Try to do the Deep Clean Printhead function on your printer to force ink through the nozzles and clean possible clogs and dirt.
The printhead has either become too clogged to flush out with with the internal cleaning operation (which uses a LOT of ink), OR, the nozzles are not firing. If after several cleaning operations there is still no significant improvement, you will need to replace the print head. I see this frequently with Canon and Epson, and Brother inkjet printers. Usually, it is due to leaving the printer idle for too long, or removing a cartridge and not replacing it right away. The air gets to the residual puddle of ink in the head and dries it. Also, using compatible or refilled cartridges can risk clogging because the ink formula is not an exact copy of the genuine Canon formula. I recommend using only new Canon carts for replacement, and do not mix Canon with non-Canon carts.
You can find the replacement print head by Google searching "MP830 print head". Prices can vary from around $70 - $90. Changing it out is fairly simple. You only need to lift a lever that holds the head in place. Make certain that it is squarely seated, and then run a few pages of a color document, or do a couple of standard cleaning operations to "prime" the head.
Make sure the hed is NEW and not used or "refurbished". Here is one source on eBay that sells it for $78.00:
http://compare.ebay.com/like/330643273134?var=lv<yp=AllFixedPriceItemTypes&var=sbar&_lwgsi=y
I had the same problem. Here's what I did to fix it:
Unplugged the printer 2x. On the first try I just plugged it back in and still had the problem. The second time I took all of the ink tanks out, unplugged it (with the power still on, don't know if this makes a difference, but that's how I did it) then plugged it back in. The printer said that it couldn't detect any ink. I reinstalled all ink tanks, and a message said that it had been shut down improperly. Press ok to continue. I test printed a picture with a lot of blue in it and the picture came out true to color of the picture.
Worked for me too. Thanks
